Old 10-14-2008, 12:20 AM   #4 (permalink)
stryker16
Mr. Taco - '01 Toyota Tacoma SR5 4x4
90 day: 16.18 mpg (US)
If you changed the size of your engine you'll definitly have recalibrate the scangauge.
What? I just changed the default 3.0L on the Scanguage to 2.7L which is what my engine size is. I didn't change me engine.
so your came stock with the 225/75 r15? 28.3 inch tire that is what mine had.
and u have a 31 .8 so more a less a 265/75 r16?
yeah it is 12% but get a gps or another car and have it do 60 and u follow and adjust gps works the best.
i went from 225/75 r 15 to a 30x 9.5 r15 which is 5.xx% but on my calubration i have a 2 in speed.
Yep. The side of my truck's door says stock tires are P225/75R15. New tires are BFGoodrich LT 265/75R16 which I found out were 31.8" This calculated to a 12% increase. I would love to use the GPS option but I can't afford one and don't know anyone with one. Maybe I'll try following a car at 60MPH though. Can you explain your reason for using 2 instead of 5% ?? Thanks
