Hi Mohammed and welcome to ecomodder. You have given me things to think about.
I do understand, and yes 200v is easy to charge.
This I will think about. Especially when cold weather and my car is in open loop mode all the time (where for a while 30% roughly more fuel is used to warm the engine). I have not tested the idea but it's possible my car rarely uses the O2 sensor to fine tune fuel trim at all...
Generally however at +90mpg until super reaches £2.40/l petrol is cheaper. At a crossover point that 30% will mean your idea would make a very big ethical change and start to save (small at first) money.
There will be transfer losses in changing the house AC to DC to a point less than 30%.
Yes your idea is sound in my opinion.
A full charge like that would contribute 5% to my daily trips as I live in the country (10-15 miles) It would also make the batteries warm and less resistant in the winter (springy like after a long drive. However at my gf's maybe up to 40% of small trips.
I wouldn't wire it to the block heater (don't have one) but the post relay terminals are easy to get to. If you did it overnight you wouldn't need a super thick cord as it's 201v dc, and it normally has to be much thicker (like an inch!), personally speaking. Have the charger/adapter so it goes in the boot.
City definitely. In my case whatever energy I use less mass means more money
Was interesting thanks
Regards
....I also had a thought why electric cars don't have multiple removable modules for people who live in flats etc, like you switch them out...
