Thread: Gasoline VAPOR?
Old 06-30-2022, 01:33 AM   #48 (permalink)
cRiPpLe_rOoStEr
Originally Posted by tomi_k View Post
Newbie on this area but modern ICE has all sort of "circulating" loops (PCV, EVAP etc.) to burn fumes / vapors again so basic system is already available...
Not exactly the same principle, considering the PCV takes vapour of the lube oil which has a considerably higher density than gasoline. Plus it takes some waste vapours, while an attempt to switch gasoline from liquid phase to vapour phase would be way more complicated to control. A more accurate comparison would be the vaporizer of some propane conversion kits, even though nowadays liquid phase propane injection has been fitted to some port-injection engines too.
tomi_k (06-30-2022)
