Old 06-30-2022, 05:55 AM   #175 (permalink)
serialk11r
Does ethanol produce NOx like petrol? I'm not familiar with the mechanism that causes it in the first place. Most of air is nitrogen and oxygen. Is it simply heat?
Yes, nitrogen + oxygen + high temperature. Any air breathing engine produces NOx.
With US refineries running at 95% capacity, if a refinery goes down over the summer, we might get $10/gal in CA...so I try to top up the fuel tanks. E85 is usually uneconomical to run in CA but right now it's cheaper per BTU than gasoline plus it's an octane booster so I am adding a bit to each tank if I drive by the Propel Fuels pump.
The Following 2 Users Say Thank You to serialk11r For This Useful Post:
pgfpro (07-01-2022), RustyLugNut (07-02-2022)
