Thread: Tire question
Old 06-30-2022, 05:09 PM   #9 (permalink)
cRiPpLe_rOoStEr
Originally Posted by Tmugz88 View Post
On our 14 Spark we have 185/55/R15 , the tires are two different brands
Just a little smaller than the 185/60R15 fitted to my mother's Yaris.
The ones up front are Falken Sincera SN250 and the rears are Lionheart lh501. I was referring to using a brand such as Lionheart which can be had for $62 from Walmart
I'd rather use some bias-ply tire from a reputable suppiler instead of a brand such as Lionheart, even if I would have to change the wheels. As there are still many traditional rear-engined Volkswagens in my country, it's not hard to find 5.60-15 bias-ply tires, and at least one local manufacturer provides a tubeless bias-ply tire specifically for the Beetle.
Well, how hard would it be to find 155R15 or 155SR15 tires from some more reputable brand there?
Basically trying to locate a brand made by one of the larger brands that is more affordable.
Euzkadi, a brand originated from Mexico, is now used by Continental for its budget range. Goodyear IIRC used the Kelly brand for its affordable range, and there might be others that I don't remember right now.
I'd prefer to go with something that is LRR or known for providing good MPG.
If you could safely fit 155R15 tires to your car, or if the 165R15 Kelly Metric could still be found there, those would be a good option, as their larger diameter would act like a higher final transmission ratio on highway, and since it's narrower the rolling resistence would likely be lower too.
