Old 07-04-2022, 08:57 PM   #183 (permalink)
serialk11r
Originally Posted by rmay635703 View Post
Great idea in the name of profit, shut down the economy
That's not private business' problem to deal with if the market doesn't compensate it for that risk.
This is a good example of an opportunity to use the state's resources to incentivize vital resource production.
Do you think something with a more Diesel-like compression ratio, and the heated injectors fitted to newer Brazilian flexfuel cars?
My cursory understanding of Brazilian cars is they all have higher compression ratios for burning ethanol right? The NOx is probably on the same order of magnitude as normal gasoline burners here.
It could be lower, but again emissions standards are very tough and there's almost nothing you can burn without producing too much NOx by new car standards.
