Two examples here. Both are in a rural setting. When you are delighted following a slow up shifting truck down an on ramp knowing everybody else will see his bulk, plus yourself supposedly trapped behind him in their eyes, allowing your acceleration to be leisurely without conflict entering the freeway. Number two is putzing Along on a rural Two lane Country Road watching your rear view mirror as you see a blob of a car about a mile back slowly starting to come up. You're wondering if you're going to have to increase your speed, or adjust it as you know the road well and are trying to plan when they might get to you and if there is a wide enough shoulder where you could do a wave them around, so you're formulating all these ideas in your mind, and as you continue to scan your rear view mirror, you see them make a turn off long before they get anywhere near you, and you smile to yourself knowing you're not going to be bothered This Time by someone.
06 Chev MonteC JG#24tribute car 30mpg 00 Honda Insight 63MPG 98 Buick Park Ave3.8 33MPG 89 Toyota Corolla wag 53MPG so far 81 VW Rabbit diesel pu 50MPG+ 80 Mercedes 240D stick 30-ish 90 vette 6-speed,29ish 07 Honda ST1300 55MPG 83 Honda 650 GL 64MPG 19 Suzuki dr200 88MPG23 HondaGrom?+Tow K10D Sub 26mpg NEVER,NEVER GIVE UP!
PUMP THOSE TIRES UP!
DRIVE IN YOUR SOCKS FOR SENSITIVITY!!!!!!!!!!!!!!!
SLOW DOWN AND SMOOTH UP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
