Old 07-07-2022, 05:16 PM   #26 (permalink)
OliverSedlacek
Interesting discussion on flaps for brake cooling. I'd be tempted to try a shape memory alloy flap actuator so the flap is opened when the brake exceeds some temperature or other. AFAIK all cars need to pass a brake test which consists of 10 consecutive rapid stops from 90% of maximum speed, so they should withstand a fair amount of heat soak.
The Following User Says Thank You to OliverSedlacek For This Useful Post:
aerohead (07-07-2022)
