Old 07-11-2022, 12:17 PM   #34 (permalink)
aerohead
purpose
Originally Posted by Plush1992 View Post
Added to the front grill block. The area I blocked off doesn't seem to have any real purpose. I don't think it really helps with cooling and sends a lot of air underneath the truck, right where I don't want it
Make sure that there's no expensive electronics with heat-sinks that will be starved for cooling air hiding in there.
My Toyota has the ignition igniter module attached to the passenger side inner fender well underneath the airbox, which receives some airflow leakage around the radiator bulkhead. It's spaced off the surface for air circulation. It's full of circuit board. Perhaps some transistors or diodes which require air-cooling.
You'll want as much money for mods as you can, rather than replacement parts for 'cooked' components.
