Old 07-13-2022, 11:14 PM   #1311 (permalink)
freebeard
I probably knew at some point, but had forgotten.
What I'd like to see is a flat four implementation of a Scuderi Cycle engine. Two cylinders running as a single stage air compressor, feeding a 120PSI tank, feeding two cylinders that run on gas or compressed air.
en.wikipedia.org/wiki/Scuderi_engine
All needed would be a custom [roller bearing] crank and camshaft, and the induction plumbing.
Meanwhile, back on Youtube:
9:40 they made a type two taxi called the Lotacao,
9:43 which had six front hinge doors in the passenger area
9:47 and four bench seats.
