Old 07-15-2022, 06:36 PM   #47 (permalink)
Talos Woten
Righteous Imaginarian
Talos Woten's Avatar
Champrius v3.2 - '09 Toyota Prius
90 day: 58.73 mpg (US)
Originally Posted by ps2fixer View Post
The job isn't bad, there's a vid on youtube that covers the process pretty well.
Actually, I plan on following your advice and doing it myself. It seems like the trickiest part is doing the coolant bleeding afterwards. But with the right plastic hose, it looks easy peasy.
You could get a temp probe that runs on 12v and wire it up in the car, glue the temp probe on the aluminum part of the inverter housing and it would give a reasonable idea on temps. The engine coolant temp is readable on the scan gauge. I plan to do a similar mod on mine at some point.
True. That could work. Or, I could just look at Torque Pro, which gives me access to every sensor in the car, including all the temperature readings.
I've attached the moment the pump failed. 215F is way too hot... especially when typical temps are 110-130F.
Champrius 4.0 is finished and up
FOR SALE.
Follow starting here:
https://www.instagram.com/p/CeeL6xyFp-k/
and ask in depth questions here:
https://ecomodder.com/forum/showthre...tml#post669277
Stats from Champrius v3.2:
