Looks like I've got a problem. My check engine light likes to come on every now and again for a small breif period of time. Like 5 seconds then off. I ran the KOER test for the OBD1 system twice and came up with a 172 code which indicates the engine is running lean. It could be something simple like I need a new o2 sensor, small vacuum leak or dirty maf sensor.
However this started happening once I switched over to those different fuel injectors.
So what's your guys opinion on this? New fuel injectors at fault? I would of assumed with a slightly higher poundage right on the new injectors it would of been running rich? Should I ignore it and carry on 🤷
