Old 07-18-2022, 08:29 PM   #38 (permalink)
mpgmike
You found injector data suggesting the new ones flow 16-19 lbs/hr versus stock 14. Is it possible the 16-19 rating was at a higher head pressure than the 14 rating? For example, if the 14 rating was at 63 psi versus the 16-19 psi rating at 47 psi? That would suggest that the new injectors may flow less at the same FP pressure. Just a thought.
Recovering Gasaholic
