Old 07-20-2022, 03:19 PM   #4 (permalink)
redpoint5
90 day: 38.47 mpg (US)
Only time I needed more than a breaker bar was to remove the bolt holding the pulley on my engine in the Acura. I used the pipe from the jack handle to extend the breaker bar several feet, then I hopped on the end until a loud bang occurred. Apparently that was the happy noise of the bolt loosening.
I put an aluminum underdrive pulley on, then snuged back up to spec, which was hundreds less ft/lbs than it took to loosen.
