Old 07-21-2022, 12:39 PM   #99 (permalink)
sregord
EcoModding DIY aer.or
Thumbs up Open end cavity
Your patience is very much appreciated.
Originally Posted by sregord View Post
I found it on page 338. Figure 8.64
..and further reading: 8.5.4.5 Add-on devices on the rear end
The only drag reductions achieved(by 5%)were by the addition of non-ventilated cavities. Figure 8.65 Base-flow modification devices
more from 8.5.4.5...The best geometry, with a cavity depth of 0.13d, reduced the drag coefficient by 5 per cent.
0.13 times 11'(tall) = 17.16"
0.13 times 8.5'(wide) = 13.26"
It's okay to be 'open' at the rear, but not the top, sides, or bottom. The 'leakage' destroys some of the pressure recovery, the whole idea for elongation. -------------------------------------------------------------------------------------
The very last iteration of the Betterflow semi is what you want, for what's presented.
They're using the full height of the trailer (minus ground clearance ) for streamlining, and their boat-tailed cavity fits snugly against the trailer van, perfectly protecting the pressure rise.
gluing, shaping, epoxing 2 or 3" thick pink foam to the perimeter of the rear edge, adding 13+" to the overall length of Moby ...like building a foam tail on an Insight... maybe?
The Following User Says Thank You to sregord For This Useful Post:
aerohead (07-21-2022)
