Old 07-21-2022, 02:16 PM   #102 (permalink)
sregord
EcoModding DIY aer.or
4,682,808, by Bilanin
I suppose, under an exact reading, Hucho's 'rear-end extension panels' qualify as a 'box-cavity', however, we can 'blow' by that performance, using Continuum Dynamics', aerodynamic backward's-facing step, captured-vortex technology.... it's at a higher static pressure, plus it's vectored towards the wake.
You end up with not only a 'smaller' wake, but a wake of higher base pressure, the goal of streamlining.
It's not as 'good' as a proper boat-tail, but it gets you 'towards' the performance, with less material, a lighter structure, and a few orders of magnitude easier to fabricate. All the reasons for Trailer Tail.
So, you are suggesting this?
https://patentimages.storage.googlea...ngs-page-5.png
by "gluing, shaping, epoxing 2 or 3" thick pink foam to the perimeter of the rear edge, adding 13+" to the overall length of Moby ...like building a foam tail on an Insight"(ala 3-Wheeler), I meant modelling the adds to the very last iteration of the Betterflow semi ...with a bottom, not retractable...since I don't need to back up to a loading dock. That would be better ..yes?
The Following 2 Users Say Thank You to sregord For This Useful Post:
aerohead (07-21-2022), freebeard (07-21-2022)
