Old 07-21-2022, 09:04 PM   #113 (permalink)
sregord
EcoModding DIY aer.or
I believe that it's one of his papers which goes into the shortcomings of NASA's boat-tail, and that of the entire tail structure of the Lockheed C-130 Hercules.
That's the one...VG's are the solution to all that is wrong with the pudgy C-130
I recommend Schedule-40. Aside from greater strength, it can pull into a fine curve, like an enormous french curve drafting tool!
Establish three accurate points, bend the pipe across them and, voila!
If you're going down the path of PVC pipe then pack it with hot sand to make any bends and allow for spring-back.
the white 1" Sch40...yes. It looks like the local HD only sells Sch40...10 & 20' lengths
Great visual aid
The Following User Says Thank You to sregord For This Useful Post:
aerohead (12-01-2022)
