Old 07-22-2022, 04:17 PM   #14 (permalink)
oil pan 4
In a diesel it will usually hurt fuel economy.
Only time EGR helps fuel economy for sure is in very cold climates.
Don't have to delete anything, just make a sheet metal gasket with no hole for the exhaust to flow through. It's all there and still "working" as far as the ecu is concerned.
EGR on diesels is known for increasing tail pipe soot, decreasing fuel economy and decreasing horsepower.
With this mod you can try it and if fuel economy goes down you can easily undo it. Also I have heard of 1.9t intake manifolds becoming horribly clogged with diesel soot.
On a gasoline engine the EGR being disabled usually decreases fuel milage. It does not effect peak power because the EGR closes at around 1/2 throttle.
Also does it have a cold air intake or intercooler?
