Did you see any fuel economy improvement by doing that? Probably not.... if understood your comments correctly....
Just trying to understand how the whole engine systems works with fuel injectors and sensors.... what sensors and where they impact and how they feed into a ECU in a closed loop system... And naturally think if there are some "easy" way to improve fuel economy by tweaking some sensors when much less power is needed (like highway driving) yet possible to adjust things back to normal when/if needed....
