Old 07-25-2022, 07:46 PM   #80 (permalink)
Isaac Zachary
High Altitude Hybrid
Avalon - '13 Toyota Avalon HV
90 day: 40.45 mpg (US)
Prius - '06 Toyota Prius
OBDII is great if you have the tools for it and the shop manual for the vehicle. Otherwise I see no difference between it and OBDI as OBDI will also give you the general codes like "bad O2 sensor signal" or "Excesive misfires" and without the need for a special scan tool as you can usually just jump a couple points and get the codes with a piece of wire.
I sure hope prices change. But as long as there's a shortage I don't see it happening. There has to be an increase in production first for used car prices to come down.
The Following User Says Thank You to Isaac Zachary For This Useful Post:
redpoint5 (07-25-2022)
