Old 07-27-2022, 12:39 PM   #59 (permalink)
beate
HPV Tussie
That's what's happening. Well, not quite - the wheel itself is stiff. It is definitely the swing arm and evenven the back part of the body. My solution was exactly the same as Yours (see above), but i also had to shorten the back a bit because it was too narrow.
Which means i will need to work on the stiffness issue before new attempts with the back are meaningful. BTW: a well known problem with these bikes.
