Old 07-28-2022, 02:37 PM   #7 (permalink)
Caddylackn
Passat TDI Wagon - '97 VW Passat Wagon TDI
90 day: 49.82 mpg (US)
Blue - '21 Hyundai Sonata Blue
90 day: 47.54 mpg (US)
Originally Posted by meatastic View Post
Monday through friday. The Corolla would either be a 2000-2006 manual ideally but there tuff to find so probly auto. I'm leaning towards echo but one user said with a/c his mpg drops 5 to 7 and that's a necessity
Some people do not know how to use A/C correctly. It must be on recirc and not on full cold. You want it to cycle on and off at the maximum temperature you can handle. Usually the compressor is only drawing engine power less than 50% of the time then. When it turns on it should only run for 30 seconds or so.
If you just drive around with it on full cold setting with fresh air vent, then the compressor is running and sucking engine power 100% of the time and it will significantly reduce your mpg.
97 Passat TDI Wagon
Bosio 520 DLC nozzles, chip tune
Mufflerectomy, ALH Injection Pump
317k miles
Scan Gauge II
full belly pan
26 gallon tank
