Old 08-01-2022, 02:52 PM   #26 (permalink)
Caddylackn
Passat TDI Wagon - '97 VW Passat Wagon TDI
90 day: 49.82 mpg (US)
Blue - '21 Hyundai Sonata Blue
90 day: 47.54 mpg (US)
Of course you may ask, why the spindle had to come completely off the car? Just remove the hub with a puller and press the bearing off and on with the spindle in place like most front wheel drive cars. I have the bearing press tools to do this.
On the Passat, there is a big spring C clip on both sides of the spindle on either side of the bearing. It would be impossible, (or close to impossible) to get this C clip off the inside of the spindle with the spindle on, even if the front axle was pulled. If I had a lift, I might have been able to see this and get it off. There is not really enough meat on the bearing to use a bearing press that clears the C clip, so pressing this off through the back side of the spindle would not be possible without destroying the C clip.
With the spindle off the car, both C clips are removed and the bearing can be pressed out and on from either side. These C clips were thick and a total PIA to get off. I broke my C clip pliers doing this, they couldn't handle the force required.
97 Passat TDI Wagon
Bosio 520 DLC nozzles, chip tune
Mufflerectomy, ALH Injection Pump
317k miles
Scan Gauge II
full belly pan
26 gallon tank
