Old 08-01-2022, 10:29 PM   #3 (permalink)
Daox
Redpoint is correct. The alternator keeps the battery topped off to the point that a little charging isn't going to make any significant change in fuel economy. If you want to disable your alternator, you need to swap in a deep cycle lead acid or other chemistry battery that has enough capacity for the trips you'll be taking.
