Originally Posted by aerohead
I believe that the Technical University of Munich reported that the Driv Aer CFD model has a 9% deviation built into it, and you'd be cautioned to accept any data results on face value.
maybe i should extend my front wheel deflectors down then. they '' look'' about 10mm. havent measure, but they are extremely small in front of the front wheels. the rear wheel deflectors are probably about 40-60mm. need to measure, but the back wheel ones are so much larger and visible. almost look like front baby mud flaps
once this heat wave ends, besides the diffuser, ill be working on better wheel deflectors ( left rear one actually split off during snowstorm in utah) combined with boat tailing wedges behind the wheels
