Thread: Prius 75-91mpg
Old 08-09-2022, 12:27 PM   #305 (permalink)
Caddylackn
Passat TDI Wagon - '97 VW Passat Wagon TDI
90 day: 49.82 mpg (US)
Blue - '21 Hyundai Sonata Blue
90 day: 47.54 mpg (US)
Use copper nickel tubing on your brake lines. It is wonderful modern stuff, won't rust, easy to bend, easy to double flare without cracking and its cheap. I bought a roll of 3/16" copper nickel brake tubing on Amazon with a bunch of fittings for like $30. You don't even need a tubing bender unless you want a perfect tight radius.
97 Passat TDI Wagon
Bosio 520 DLC nozzles, chip tune
Mufflerectomy, ALH Injection Pump
317k miles
Scan Gauge II
full belly pan
26 gallon tank
The Following User Says Thank You to Caddylackn For This Useful Post:
COcyclist (08-20-2022)
