Old 08-09-2022, 01:15 PM   #40 (permalink)
Caddylackn
Passat TDI Wagon - '97 VW Passat Wagon TDI
90 day: 49.82 mpg (US)
Blue - '21 Hyundai Sonata Blue
90 day: 47.54 mpg (US)
A B A B A testing results Air Dam versus full undertray with diffuser
Some A B A B A B A B A Testing results with the full undertray and no air dam.
compared to A B A B A B A B A B results with the air dam and diffuser only.
-Using Scan Gauge II trip, no fill up yet.
-Using my GPS speedometer my car is showing about 3% off (speedometer reads high) so Scan Gauge II is probably reading 3% high. Not calibrated yet
-A = ride to work 20.8 miles.
-B = ride home from work 20.8 miles. 1,400' elevation gain 1,500' elevation drop (100' net elevation drop) to work, 100' net el' gain home.
-Drives are 57- 60 mph on interstate (speed limit of 60 mph), and 45-50 mph in 45 speed limit. About 2/3 of the commute is interstate and 1/3 at 45 - 50 speed limit.
-Coast in neutral with engine on, as much as possible. About 1.5 miles of trip is 30 mph speed limit and steep.
At least 3 miles of entire trip is just coasting.
With air dam and diffuser;
To work (trip mpg)..............Home (trip mpg)
67.9 .................................64.3
71.7..................................67.7 3 mile shortened trip
66.9..................................62.2 3 mile shortened trip
68.2..................................64.2
68.3..................................69.4
With Full Undertray tied to diffuser
78.2....................................77.4 To work from gas station to work only
81.7....................................76.1
83.7....................................78.6
82.5....................................79.4
81.8....................................79.5
85.3...................................... - New all time high trip this morning
I can easily see the difference driving and coasting. I can reach 75 mpg on flat road at 60 mph and I can coast way farther now. I am getting 35 mpg on the big hills that I used to struggle to get 32 mpg on. I can now link several shorter coasts into one long coast.
I did install new front wheel bearings the same time as I installed the undertray so that does skew the data a little.
97 Passat TDI Wagon
Bosio 520 DLC nozzles, chip tune
Mufflerectomy, ALH Injection Pump
317k miles
Scan Gauge II
full belly pan
26 gallon tank
The Following User Says Thank You to Caddylackn For This Useful Post:
Piwoslaw (08-09-2022)
