Old 08-11-2022, 11:15 AM   #18 (permalink)
aerohead
lowest pressure
Originally Posted by Logic View Post
All this talk of ram air makes me wonder if the opposite isn't true at the other end..?
ie: Where's the lowest pressure area at the rear of a car? And why doesn't the exhaust exhaust there..??
Yes it's all about keeping CO low, rather than smothering fellow motorists, but perhaps one of those exhaust valves can be made to work at higher speeds where it will be useful.
Hmm... you'd likely want the exhaust sealed where it goes through the rear panel.
Not so easy..?
The lowest pressure will occur along the sides of the vehicle, not the rear.
Exhausting to the rear requires that zero leakage occur at the trunklid (boot) seal, and seal between trunk and rear seat/cabin.
It's the reason NASCAR demands side pipes to dilute tailpipe gases which could be inhaled during 'drafting.'
COcyclist (12-01-2022), Logic (08-15-2022)
