Old 08-12-2022, 04:30 AM   #48 (permalink)
Xist
Greetings fellow humans
Mom insisted we leaving at 1000 Tuesday morning, but she kept on insisting on running into different stores.
The lady who I had sit in my wheelchair so I could push her to the car when I got out of the hospital.
Always running.
It had sounded like I would be able to see my clients, but on much shorter notice than I would have liked I needed to ask to reschedule.
I wasn't able to work on my car the rest of the day.
I made up a session on Wednesday and saw a client 45 minutes away. When I came home Mom yelled that apparently there was a barbecue at the Bishop's house, which she found out 40 minutes before it was supposed to start, so she yelled at me until we arrived.
It was lame.
I couldn't wait to go home.
I dropped them off and went to Lowe's for some wire brushes for Mom's Dremel, which I tried to use today, but apparently you need to use Dremel brushes on low speed:
This cost $7.50 and disintegrated in 30 seconds.
The 400-grit sanding sponge didn't seem to do much. I will use 240-grit sandpaper on the paint and just spend more time on the mating surface.
Then I finally repaint?
Ecky (08-29-2022)
