Old 08-12-2022, 04:51 PM   #44 (permalink)
seuadr
Stitch with Zip ties. If every other tie is backed with a ring of 3/4" PVC pipe it holds the edges in alignment.
Use a veneer face facing inward, add insulation and fiberglass to the outside?
Yeah I've been reading about combining a stitch and glue approach with a vac bag - so you do just 1 side at a time to the basic interior shape, then the foam will remain flexible on the other side and you can stitch it and glue, using a vsc setup to make sure there are no pockets.
