Old 08-16-2022, 10:29 AM   #143 (permalink)
redpoint5
90 day: 29.78 mpg (US)
Not to be picky, but you did essentially the equivalent to replacing the battery with the fuel drain, although MUCH more economical
That's exactly the point I make on the EV forum; that a battery is equivalent to a fuel tank. One that costs thousands of dollars, weighs a ton, takes up a lot of space, takes ages to fill, shrinks in capacity over time, and requires environmental regulation (heating/cooling). It's the only thing that sucks about an EV.
Usually that's when I go on about the merits of PHEVs, because they minimize the thing that sucks the most (battery) but maximize its use.
The Following 2 Users Say Thank You to redpoint5 For This Useful Post:
Ecky (08-18-2022), Isaac Zachary (08-16-2022)
