Old 08-16-2022, 07:04 PM   #8 (permalink)
redpoint5
90 day: 29.78 mpg (US)
Originally Posted by serialk11r View Post
If you search you'll find a lot of posts.
There's zero reason to assemble the pack yourself nowadays, as they make plastic casings that fit standard car/motorcycle battery sizes with standard size terminals.
Except I can get 7 Ah cells for $3.50 apiece on Aliexpress. I load tested the cells and found them to very nearly get the claimed capacity, which is always hit or miss, especially on Chinese sourced cells.
A 4s4p config would cost $56, 28 Ah, and 200+ short duration discharge capability.
One can scale as needed to achieve their capacity and power requirements.
I've used one of the 20Ah batteries from here for years:
https://www.batteryspace.com/li-ion-...lead-acid.aspx
Same. Spent like $120 and didn't even add balancing or BMS of any sort. 6 years trouble free in the Prius so far.
The Following 3 Users Say Thank You to redpoint5 For This Useful Post:
Ecky (08-16-2022), Logic (08-17-2022), serialk11r (08-16-2022)
