Old 08-22-2022, 05:42 PM   #87 (permalink)
Isaac Zachary
High Altitude Hybrid
Avalon - '13 Toyota Avalon HV
90 day: 40.45 mpg (US)
Prius - '06 Toyota Prius
You ever own a VW? You can't even check spark plugs without removing the exhaust manifold, and to do that you need Torx tools because it would be too easy if VW just used standard hex bolts.
Only VW I'd own would be under warranty, which means I'll never own one.
Not newer than 1985. Also a 1972 VW. I do have a pretty good set of Torx tips.
