Thread: Rear diffuser?
Old 08-25-2022, 10:41 AM   #73 (permalink)
IRONICK
IRONICK's Avatar
If you'll do additional heat-shielding, exhaust wrap, or both, heat shouldn't be an issue. ICBM missile silos use nothing but concentric rings of sheet metal shells with dead air spaces in between to insulate them.
Kenny Lyon's BMW exhaust system was completely-wrapped on his Cd 0.11 streamliner motorcycle. And he was 'inside' the body at all times, with the exhaust!
Don't need any insulation, an aluminum plate with one air inlet and many exits along the central tunnel.
The Following User Says Thank You to IRONICK For This Useful Post:
aerohead (08-25-2022)
