pressure increased in the wheel well creates drag and lift both and noise. the vents all the air to exit out of the high pressure wheel wells
Your just restating the most obvious thing. My example was from 1981.
It doesn't answer what is a 'separation trap' anyway. How does it differ from a Faschenfeld tearing edge [as seen on the new Prius]. It's in the bumper, is that them below the reflectors?
Here's a properly designed front fender.
This one has a tight raidius, but massive venting on the top.
