Old 08-31-2022, 11:09 AM   #12 (permalink)
Isaac Zachary
High Altitude Hybrid
Avalon - '13 Toyota Avalon HV
90 day: 40.45 mpg (US)
Prius - '06 Toyota Prius
Originally Posted by Logic View Post
'sharp-ish' points on the piston face or in the head tend to get hotter than other areas and can also start knock.
That's also been myth-busted. Sharp edges in the right spots can actually decrease knock as it can help fuel to reatomize. One of the worse combustion chambers for knock was the hemispherical head.
IIRC thats why spark plugs often have copper in the electrode; to get the heat out of it and prevent this.
Sparkplugs have various levels of insulation to keep their temperatures up. It depends a lot on the application, but the idea is hotter, insulated spark plugs keep the carbon burned off. Too much insulation and therefore too hot of a spark plug could cause a problem such as pre-ignition.
