I took some measurements. The step-over height of the center tunnel is nine inches. The floorboard is 8-12" wide. I didn't get the width of the battery box.
If the battery box was a flat plate 3" thick it seems they could have a flat floor. The 1.x platform is incremental. There shall follow a 2.x platform.
Don't make any movements easier than you are capable of managing, because you don't get 'em back.
Do everything the hard way? Because YOLO?
I'm currently bike-less -- broken rear axle. Schwinn Collegiate Unobtainium? I'm thinking the best solution might be the MIT wheel, or some modern equivalent. The MIT wheel had the batteries right in the wheel.
Mean Lean Machine is maybe two years away.
