Old 09-01-2022, 03:47 PM   #849 (permalink)
freebeard
A/not A, there is no B?
A friend lives in an area...
One of her goals...
aerohead has a friend. Good on you.
https://www.amazon.com › Ceramic-Houses-Earth-Architecture-Build › dp › 1889625019
Ceramic Houses and Earth Architecture: How to Build Your Own: Khalili ...
Nader Khalili, an Iranian-born California architect and author, is the designer and innovator of the Geltaftan Earth-and-Fire System known as "ceramic houses" as well as the Superadobe building technologies. He received his education in Iran, Turkey, and the United States, and has been a licensed architect in California since 1970.
He expended one 50-gallon drum of kerosene per house. The problem is yield rate. If it fails, it's hard to bulldoze the result.
My proposal involves a concave form, a pendular print head, an Olds Elevator to lift the mix and wind power like a cherry on top. Multiple hexagonal 'greenware' panels stack up in a kiln. Fire once to stoneware, second firing to glaze them with Ultrawhite on the outside and decorative colors on the inside.
Non-planar 3D printing can produce any compound curve. Think Antoni Gaudi.
You can't be wise and in love at the same time. -- Bob Dylan
aerohead (09-01-2022)
