Old 09-01-2022, 08:11 PM   #13 (permalink)
Logic
Originally Posted by Isaac Zachary View Post
That's also been myth-busted. Sharp edges in the right spots can actually decrease knock as it can help fuel to reatomize. One of the worse combustion chambers for knock was the hemispherical head.
Thx for the vids: Interesting stuff!
But i think we're mis understanding each other here.
I'w as talking more about burs from machining and unfinished/polished castings than the 'less sharp' edges etc in the vids.
Sparkplugs have various levels of insulation to keep their temperatures up. It depends a lot on the application, but the idea is hotter, insulated spark plugs keep the carbon burned off. Too much insulation and therefore too hot of a spark plug could cause a problem such as pre-ignition.
I'm aware of the heat range and self cleaning etc.
But the ground electrode can get too hot from what I understand and that's where copper and even silver is employed to conduct the excess heat back into the plug body, keeping the plug temperature more uniform..?
https://www.performanceracing.com/ma...ht-spark-plugs
