Old 09-06-2022, 07:12 PM   #874 (permalink)
oil pan 4
It may want to wait a few hundred thousand years. Marine biologists are confident that carbonic acid from CO2 entering the oceans will prevent shellfish and crustaceans from forming shells in the not-so-far future.
Any calcium carbonate formed on a ferrous armature during electrodeposition would just dissolve and return to solution.
You can take a piece of hamburger in the evening, and drop it into freshly-opened Coca-Cola, and by morning, it will be 'gone.'
At Yellowstone National Park, if you have the 'time,' you can watch carbonic water surface onto 'Minerva's Castle,' and as it evaporates, leaves a new layer of limestone behind, an 'ocean in reverse.'
Then why didn't that happen when CO2 levels were 1,600ppm not that many millions of years ago.
aerohead (09-08-2022)
