Old 09-08-2022, 12:51 PM   #3 (permalink)
Caddylackn
Passat TDI Wagon - '97 VW Passat Wagon TDI
90 day: 49.82 mpg (US)
Blue - '21 Hyundai Sonata Blue
90 day: 47.54 mpg (US)
I would say look at all the usual things on the car. Many are the same: suspension, steering, brakes, wheels, tires, rust, A/C, window motors, etc.
Does the car drive well? Shakes or shimmys driving it at highway speeds? Does it stop well? Do brakes squeak, pulse, or fade? Does the car have any rust? Does it have any codes? Do all the lights work? Wipers? Seat heaters? Fan? Does the car have wind noise from bad seals? Does the electrical motor make any unusual noises?
Do you need 240 Volts to charge adequately for your use?
IDK anything about the Leaf. If your electrical panel is in the garage, it is not that hard to add a 240 V 30 amp circuit if there is room on the panel for one or two new breakers.
97 Passat TDI Wagon
Bosio 520 DLC nozzles, chip tune
Mufflerectomy, ALH Injection Pump
317k miles
Scan Gauge II
full belly pan
26 gallon tank
The Following User Says Thank You to Caddylackn For This Useful Post:
broski499 (09-08-2022)
