Old 09-09-2022, 01:00 AM   #6 (permalink)
some_other_dave
IIRC, the R and L series engines rotate the opposite way from the D series--and have the transmission on the opposite side of the engine bay! That means the mechanical part of the swap is more involved with them, versus the D or B swaps. (Not sure about the K series.)
I like KISS--D-series to D-series is the most straightforward swap, plus you already know you like what you have. If you're interested in better freeway MPG, you may be able to find a taller 5th gear for your transmission.
The Following User Says Thank You to some_other_dave For This Useful Post:
JacobLeSann (09-16-2022)
