Old 09-13-2022, 03:15 AM   #9 (permalink)
BamZipPow
T-100 Road Warrior
BamZipPow's Avatar
BZP T-100 (2010) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 24 mpg (US)
BZP T-100 (2011) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 23.66 mpg (US)
BZP T-100 (2009) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (2012) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 25.45 mpg (US)
BZP T-100 (2013) - '98 Toyota T-100 SR5
Last 3: 25.79 mpg (US)
BZP T-100 (2014) - '98 Toyota T-100 SR5
Last 3: 23.18 mpg (US)
BZP T-100 (2015) - '98 Toyota T-100 SR5
Last 3: 23.85 mpg (US)
BZP T-100 (2016) - '98 Toyota T-100 SR5
Last 3: 17.62 mpg (US)
BZP T-100 (2017) - '98 Toyota T-100 SR5
90 day: 20.78 mpg (US)
BZP T-100 (2018) - '98 Toyota T-100 SR5
90 day: 20.19 mpg (US)
BZP T-100 (2019) - '98 Toyota T-100 SR5
BZP T-100 (2020) - '98 Toyota T-100 SR5
2012 Scion iQ - '12 Scion iQ Base
Send a message via ICQ to BamZipPow
Wink
I'd hoped you learned the lesson about wood in the underbody.
What are the dimensions of the quadrilateral -- aft body width, aft trailer width and the distance between the two?
Will the combo have a full length diffuser with a flexible section at the hinge line? To absorb half the suspension travel?
Wood was a good low cost material fer learning with but now with the current pricing, I'm looking at other materials. EMT conduit with Maker Pipe connectors would be a good start. It should be easy to make a shopping cart frame using the connectors and EMT.
https://makerpipe.com/
I'm also considering including a mix of slotted angle as well.
I'm not sure about the underside at the moment but it will be considered in the near future.
The trailer frame is about 3' wide by 4.5' long. The space between the end of the vehicle and the front of the trailer is about 18" and from the end of the vehicle to the landing gear arms is about 13". The fiberglass body will be used sparingly as I work on building a modular body system that can be removed/replaced as needed depending on the task at hand.
Dark Aero-The world's first aerodynamic single wheel boat tail!
The Following 2 Users Say Thank You to BamZipPow For This Useful Post:
aerohead (09-15-2022), freebeard (09-13-2022)
