Old 09-14-2022, 08:45 PM   #5 (permalink)
EcoCivic
Originally Posted by Blacktree View Post
Low idle RPM shouldn't hurt it. What hurts an engine at low RPM is when you put load on it (i.e. lugging the engine). Long as it has oil pressure, you should be fine.
Thanks, that's pretty much what I'm thinking. Now that I lowered the idle I don't take off or creep forwards/backwards without using the gas anymore, I always bring the RPM up to 800+ before letting the clutch out. I'm not sure taking off from low idle without bringing the RPM up is really "lugging", but it doesn't seem to like it so I don't do it.
