Originally Posted by samwichse
It seems like ICE cars would be ideal for using an absorption AC system, given all the waste heat. But I've never heard of a single manufacturer using it. There must be some gotcha I'm missing.
For instance, my work uses this type system to provide AC from steam:
https://www.lg.com/global/business/a...ler-steam-type
Absorption AC would basically be "free" in terms of fuel consumption.
Some of my neighbors are still using refrigerators which use it.
They're horrifically inefficient, as far as input energy per net cooling effect.
Some use anhydrous-ammonia as the working fluid, deadly poison if it leaks.
'Industry'-scale Lithium-bromide chillers are boot-strapped onto the waste-heat side of natural gas-fired turbo-generators for refrigeration ( AeroStealth operated one by Solar Corp., at the University of New Mexico, at Las Cruces.
They'll also run off flat-plate solar collectors.
They're only for 'stationary' applications. No G-forces allowed.
