Thread: Realtime CFD ?
Old 09-19-2022, 07:27 PM   #13 (permalink)
freebeard
You just showed your hand and by your own doing revealed the vacuity of any command of the subject.
"Showed your hand"?
I don't claim 'command of the subject'. An unsorted keyword list is not informative. Which would be the salient line item?
Why aren't lattice Boltzman and OpenVDB pertinent?
I shan't experiment with Fluid X3D until my 3D printer is back up and running. Then we can compare notes.
edit:: I looked at the system requirements.
Compatibility
works in Windows, Linux and Android with C++17
runs on any hardware that supports OpenCL 1.2, from any vendor (Nvidia, AMD, Intel, ...)
So to run it on an M1 Mac Mini I'd have to install a new operating system. There was one Linux distro I was going to watch. If I remember the name....
2nd edit:
https://screenrant.com › install-linux-m1-mac-shouldnt-why
You Can Now Install Linux On An M1 Mac, But You Probably Shouldn't
25 Mar 2022 Asahi Linux For M1 Macs The Asahi Linux installer allows setting up a separate partition to boot directly into Linux on an Apple Silicon Mac and runs well with a few limitations. The GPU card isn't enabled and admittedly will take quite some time to get working. That means gaming will not work and it can't even handle video streaming.
Maybe Ubuntu in a VM?
________________
Because much of what is in the published literature is nonsense,
and much of what isn’t nonsense is not in the scientific literature.
-- Sabine Hossenfelder
