09-26-2022, 02:07 PM
#26 (permalink)
They created code which [interrogated two, pre-broadcast, adjacent lines] which would emerge, placed in between the real signal material, across a video screen, [interpolating a 'new', artificial broadcast line] from their algorithm, creating a high-resolution image from low-res..
Reviewing https://en.wikipedia.org/wiki/Digita...ve#Compression
The original video compression scheme, called Presentation Level Video, was asymmetric in that a Digital VAX-11/750 minicomputer was used to compress the video in non-real time to 30 frames per second with a resolution of 320x240. Encoding was performed by Intel at its facilities or at licensed encoding facilities set up by Intel.[4] Video compression involved coding both still frames and motion-compensated residuals using Vector Quantization in dimensions 1, 2, and 4. The resulting file (in the .AVS format) was displayed in realtime on an IBM PC-AT (i286) with the add-in boards providing decompression and display functions at NTSC (30 frame/s) resolutions.
So they capture a still frame and then extract the differences in subsequent frames to upscale from 320x240 to NTSC (640x480).
Currently upscaling is available as a free or paid service online: duckduckgo.com/?q=AI+upscaling&t=raspberrypi&ia=web
The new hotness is outpainting:
https://www.dpreview.com › news › 8850471712 › openai-adds-outpainting-feature-dall-e-allowing-users-to-make-ai-images-of-any-size
OpenAI adds 'Outpainting' feature to its AI system, DALL-E, allowing ...
2 Sept 2022Outpainting can extend original images, create larger images in different aspect ratios, and much more. Plus, the system considers existing shadows, reflections and textures, to help make newly-generated content appear natural. Outpainting is now available to all DALL-E users on a desktop. If you'd like to join the public beta, join the waitlist.
.Moore’s Law suggests that good things come to those who wait. Wright’s Law says that good things come to those who act.
