Old 10-09-2022, 08:00 PM   #285 (permalink)
Tahoe_Hybrid
2020 - '08 Chevy Tahoe H
Last 3: 18.4 mpg (US)
2021 - '08 Chevy Tahoe H
90 day: 17.08 mpg (US)
2022 - '08 chevy Tahoe LT
Last 3: 14.38 mpg (US)
2023 - '08 Chevy Tahoe
Last 3: 22.61 mpg (US)
2024 - '08 Chevy Tahoe
90 day: 22.35 mpg (US)
Originally Posted by drmiller100 View Post
One idea I've been contemplating.
use a diaphragm pump to pump water to 50 psi or so. Run the line through copper, then heat it off the exhaust so the temps get up somewhere near 250 degrees or so.
then run it through a fuel injector, and inject it under the throttle body.
Piggy back the fuel injector off the main throttle body fuel injector so the pulse width is the same as the fuel injectors pulse width.
The idea is the water would follow fuel flows, which obviously is a pretty good indication of engine loads.
The higher temperature of the injected water means when the water hit the intake manifold it would pretty well atomize - you would not get pure "steam" per se, but you SHOULD get pretty good atomization, just like the fuel gets atomized by the injector pretty well.
ultra sonic vaporizer this is what you're looking for why not cut out the middle man???
https://www.ebay.com/itm/40297116134...Bk9SR4ji6u_3YA
