Old 10-10-2022, 01:57 PM   #55 (permalink)
seuadr
Depending on the final drive ratio I would expect you could hit 15 mpg without issue.
looks like it is probably a 4.10 i have not verified the tag, though - that is what the VIN lookup indicated.
i'm thinking 3.83 will help a bit, and it looks like that was an option for the 1 ton axle.
Are you planning to change the entry door at all? I looked at busses but one of the reasons I ruled them out was they have the entry steps where a front passenger seat would be.
yeah i'm just not sure exactly how yet. the bottom of the door is rusty and so needs something done anyhow - but i'm not convinced that having a rear entry or converting the rear side door will make sense for clearing in a parking space, and, i don't want everyone to have to climb through the drivers door.
tentative idea is to remove the extra height added by the top step/platform and either repair the existing door, or replacing it, unless once i take a more critical look at the back some kind of extending stairs seems to make more sense (that would be my preference, just not sure that the clearance is there)
Have you worked out insurance yet? I have my ambulance insured with Progressive. They won't write a RV policy on a vehicle that used to be a bus.
i actually got lucky there, as because it isn't a school bus, it was titled as a van/cutaway which as far as the insurance company is concerned is NOT a bus, so it was not complicated.
i was prepared to have to fight to get it titled differently if they were going to consider it a commercial vehicle but it worked out well.
they want to re-inspect it if i decide to re-title it to an RV, but the underwriters said that was essentially to make sure that we didn't do anything to compromise the frame or install questionable stuff like a wood burner in it (which is fair) Apparently, that is a really popular "van life" mod and a bit time no-no for them.
