Old 10-12-2022, 10:34 PM   #32 (permalink)
freebeard
I went back to look. OP actaully cites a half-dozen other users, who had results that vary in quality.
deejaaa's box cavity is the low end. I thought trebuchet03 was the most interesting:
Airdams need a minimum a notch in the center. This goes to the extreme where is more of a wheel spat.
As concerns attaching Coroplast, it's an Okay material for prototyping but you'll never get to OEM let alone show quality with it. I propose Polymetal (Alumapanel, MaxMetal, etc.). It's a plastic sheet with alumninum skins and baked enamel finish. It's good for simple curves but not compund curves. I did some experiments with scrap.
Sheared, braked and rolled on bench-mounted hand tool (18" lever), Seam across the curve has an H-channel join, the brake shows it needs to be scored on the inside to prevent rupture.
The important thing is it's prefinished. Compare with sanding down fiberglass. Here's how you'd get compund curves.
Insofar as sheet metal screw, they have double-sided tape used to mount automotive trim pieces.
